Discussion topic: The Satellite keeps going off, then coming on again and then going off again.
This message was authored by: PeterPain
For the last two weeks there has been an intermittent satellite signal. It stays on for a day, then goes off, then comes on again.
Re: The Satellite keeps going off, then coming on again and then going off again.
@PeterPain
When a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Avatar for PeterPain
No. I need an engineer to assess it. I am paying for a service which is not being provided.
@PeterPain
Then you'll need to call Sky and book an engineer.
