Discussion topic: Tell me to insert viewing card with the chip facing up i have trun me tv and sky box of 4 time and ?
Message posted on 14 Mar 2024 09:58 AM
My home page is saying to insert viewing card with the chip facing up I have trun my TV and sky box of 4 times and it still not coming on .
Message posted on 14 Mar 2024 10:04 AM
Re: Tell me to insert viewing card with the chip facing up i have trun me tv and sky box of 4 time a
Hi @Kelly2975
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Make sure that it is in chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
Message posted on 02 May 2025 05:24 PM
My sky box is saying insert my card but it's already in
Message posted on 02 May 2025 05:28 PM
It's not working
Message posted on 02 May 2025 06:11 PM - last edited: 02 May 2025 06:11 PM
