Discussion topic: Technical fault, white box has no power
Message posted on 09 May 2024 02:13 PM
The white box that connects to sky q has no lights lit up, not even power light, I've unplugged and plugged back in but no change.
Message posted on 09 May 2024 08:20 PM - last edited: 09 May 2024 08:20 PM
Re: Technical fault, white box has no power
@Andrea2421 wrote:The white box that connects to sky q has no lights lit up, not even power light, I've unplugged and plugged back in but no change.
Are you talking about your internet router? If so (and it is Sky broadband) then you'll need to give them a call. You can check via the My Sky app on your mobile for faults in your area first though.
