Discussion topic: Technical fault on mini box and no sky go or recording
This message was authored by: Hector1
Technical fault on mini box upstairs and not recording on any box can't get sky go on laptop or phone yet main box says everything is ok with connecting
Re: Technical fault on mini box and no sky go or recording
@Hector1 Have you tried rebooting your main Q box ie
then
try  rebooting your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
