Discussion topic: Technical fault on all channels
This message was authored by: Nicci1
Technical fault on all channels turned all off rebooted still nothing no adverse weather working fine this morning
Re: Technical fault on all channels
hi @Nicci1
Please see the following page that covers a few problems - if you follow the link through and still have problems then you should find a link to book an engineer if you have your own dish
https://www.sky.com/help/articles/sky-q-picture-problems
If you have a communal system you may have to contact your building management to deal with the technicians responsible for the system
Hi @Nicci1
Check also the following link
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
