Technical fault for downloading
Viewer
Post 1 of 3
The box let’s us select to download something but either gets up to about 114% and won’t let us play or says technical fault. Please assist us
Researcher
Post 2 of 3
Re: Technical fault for downloading
Hi, I’m  having the same problem, phoned Sky today and they are aware of a fault. This should be rectified in the next software update. He did talk me through resetting the box, it worked for a couple of programmes & the problem has now reappeared. Also, I found that the reset stopped my main handset from working until I went through the process of remarrying it.
Sky Q 2TB
TV: Samsung UE40ES7000UXXU (ES7000 Series 7)
Sound: Panasonic SC-HTE80EB-S Speakerboard
Router: BT Smart Hub (latest)
Powerline: Devolo dLAN 500
Oracle
Post 3 of 3
Hi @Brodick1869
Welcome to Q forum.
First try rebooting your main Q box.
Disconnect power lead for 30 sec and then reconnect to reboot.
If this doesn’t solve your issue
You could try a Reset Settings in the hidden menu
To enter
  • Press the 'Home' button on your remote control.
  • Scroll down to 'Settings' and DO NOT press select.
  • Press '001'.
  • Press 'Select'
Only carry out out the first reset (Reset Settings) as the other two will lose your recordings.   If you have a Bluetooth touch remote this will need to be re-paired after the reset.   Just press 1 & 3 together on the remote and follow onscreen instructions.
