Discussion topic: Technical fault during purchase in sky store now can’t get any of my recordings?
Message posted on 19 Jul 2023 08:52 PM
Technical fault during purchase has meant I can't get any of my recordings. Can see TV, catch up TV, on demand, sky store. Have tried switching off and unplugging but still not able to access recordings?
Message posted on 19 Jul 2023 08:56 PM
Re: Technical fault during purchase in sky store now can’t get any of my recordings?
Hi @Reillsdos
Message posted on 19 Jul 2023 09:31 PM
Thanks, but unfortunately that didn't work.
Message posted on 19 Jul 2023 09:33 PM
hi @Reillsdos
What message do you see when you try to Access your Recordings?
Message posted on 19 Jul 2023 09:38 PM
It just says Please wait and a circle keeps going round next to it
Message posted on 19 Jul 2023 09:42 PM
Hi @Reillsdos
See if you can make a new recording.
If you cannot, check the following link as you may have a Hard drive issue.
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Message posted on 19 Jul 2023 09:51 PM
Correct! When I try to record I get a message that says 'this service is not available because of a problem with your hard disk drive'. I don't want to do a hard disk reset and lose all my recordings though?
Message posted on 19 Jul 2023 10:39 PM
@Reillsdos if you dont follow that the only other option would be a new box and you would lose all your recordings anyway so nothing to lose by doing the hard disk reset
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
