Discussion topic: TV on but unable to play live coverage nor recordings and remote will not defer to antenna
This message was authored by: Ickers36
No response via remote regardless of what I select other than changes to left hand menu 😩
Re: TV on but unable to play live coverage nor recordings and remote will not defer to antenna
Hi @Ickers36
Try rebooting your Q box
If you had to press the Standby button on the front of the Q box to turn it on then
Try completly resetting your Bluetooth remote.
Avatar for Ickers36
Non responsive remote other than bringing up menudo
TV on but ' nobody at home ' as menus selected ok but no live transmission nor recordings being played
Avatar for Ickers36
Thank you and will give that a try 🤞👍
Avatar for Ickers36
Well done mon ami as now working properly again great help and how much do I owe you other than gratitude 😂 👍
