Discussion topic: TV never connected to internet/ internet not working - please help
Message posted on 06 Sep 2024 08:59 AM
I feel like this is my last desperate attempt to get this resolved. Every time we turn on the TV it says 'it doesn't look like you are connected the the internet right now' (images attached) this is a daily occurrence and the tv upstairs can't connect at all the majority of the time (image also attached).
we are constantly having to use 5g rather than WiFi on our phones as this also never works! I have called sky on several occasions and they have told me twice now that they are going to refund me £25 as the boost box simply isn't working. This hasn't yet happened. We are literally paying for a service that doesn't work!! We have an office upstairs which we worked from (when working from home) this now no longer works either! We have had to set everything up downstairs and use an Ethernet cable which runs through the house - it's just not acceptable. I pay almost £120 a month for this and I simply don't know what to do. I have booked in an engineer but they can't come out until 26th September!! It's not acceptable. Every time I speak to someone at sky they seem to make so many promises and nothing is ever followed up on - especially taking off the £25. I doubt this will ever even happen. Just as an example, I have started to write down what has been happening each day and this is only 3 days worth. Bear in mind that this has been happening for the most part of this year! See below:
4th September
- internet not working on main tv (won’t connect to apps/ home page etc)
- Entire tv not working upstairs, won’t connect to box
5th September
- had to re-start internet
- Have to use 5g as WiFi not working on phones
- Tv still shows as not being connected to internet after re-starting
- Tv not connecting to internet all day after that
- Have to work from home with Ethernet cable
6th September
- Tv no connection to internet, have to re-start again
- Turn everything off and on, still no internet
I simply don't know what to do at this point. Sky seem to have no interest whatsoever and I'm paying such a high amount for a service that just doesn't work! I had an employee tell me that she's personally going to look after my case and ensure the money is refunded and low and behold, it's still not happened. I just don't need this at the moment.
Message posted on 09 Sep 2024 10:42 AM
Re: TV never connected to internet/ internet not working - please help
Need to reduce deal
Message posted on 09 Sep 2024 11:12 AM
Ok the box upstairs will most likely never work if the main box doesn't have a connection. It's completely dependent on it.
You are on Sky broadband I assume?
What bost device are you refereing to?
Where is the router relative to the Q and mini?
