24
This discussion topic has been answered Discussion topic: TV loosing volume & switching off & on when fast forwarding sky q
This message was authored by: aarondowds
Looking for help. My TV keeps loosing volume & switching off when fast forwarding sky q
This message was authored by: Chodley Answer
Re: TV loosing volume & switching off & on when fast forwarding sky q
I would still try resetting it and picking the model again Random stuff happens. Neutrino from space hits a transistor etc 😉
Sounds like the remote is set up for the wrong TV model
Avatar for aarondowds
Level 2 icon
thanks for the reply, I have been using the same remote since the start but its only just started doing it recently
I wouldn't expect it to change its coding but
Might be worth re-doing it anyway.
or a button is stuck down?
Level 2 icon
Thank you, I have reset it, fingers crossed.
This message was authored by: RayH73
Did that work? We have same problem
Level 2 icon
No it didnt work,still having the same issue, it is driving me nuts, too many people complained for it to be my TV , Im starting to think its sky now
What TV is it? Do you both have the same ?
Good question. LG TV model
43NANO756PR
Level 2 icon
Mines is also an LG but a different model. Im wondering if there is a setting needing adjusted
I think it's possible to use various LG IR codes on the Sky remote. Maybe some work better than others.
Level 2 icon
I know nothing about IR codes, maybe time to call sky , this is driving me crazy
This message was authored by: kanny
Hi, did you find a solution? I'm having the same issue this week. Also have LG tv
Level 2 icon
still no solution to this, driving me mad, I have checked software updates, reset the system, retuned the remote, still the same, surely everybody cant have a faulty lg tv
It's so annoying! It's just done it 3 times in the last hour.
