10 Sep 2023 05:14 PM
Looking for help. My TV keeps loosing volume & switching off when fast forwarding sky q
20 Sep 2023 07:59 AM
Posted by a Superuser, not a Sky employee. Find out moreI would still try resetting it and picking the model again Random stuff happens. Neutrino from space hits a transistor etc 😉
10 Sep 2023 06:26 PM - last edited: 10 Sep 2023 06:26 PM
Posted by a Superuser, not a Sky employee. Find out moreSounds like the remote is set up for the wrong TV model
10 Sep 2023 08:51 PM
thanks for the reply, I have been using the same remote since the start but its only just started doing it recently
10 Sep 2023 09:03 PM
@aarondowds wrote:thanks for the reply, I have been using the same remote since the start but its only just started doing it recently
I wouldn't expect it to change its coding but
Might be worth re-doing it anyway.
or a button is stuck down?
11 Sep 2023 08:55 AM
Thank you, I have reset it, fingers crossed.
13 Sep 2023 11:03 PM
Did that work? We have same problem
14 Sep 2023 08:54 AM
No it didnt work,still having the same issue, it is driving me nuts, too many people complained for it to be my TV , Im starting to think its sky now
14 Sep 2023 09:29 AM
Posted by a Superuser, not a Sky employee. Find out moreWhat TV is it? Do you both have the same ?
14 Sep 2023 09:43 AM
Good question. LG TV model
43NANO756PR
14 Sep 2023 10:27 PM
Mines is also an LG but a different model. Im wondering if there is a setting needing adjusted
14 Sep 2023 10:46 PM
Posted by a Superuser, not a Sky employee. Find out moreI think it's possible to use various LG IR codes on the Sky remote. Maybe some work better than others.
15 Sep 2023 09:00 PM
I know nothing about IR codes, maybe time to call sky , this is driving me crazy
19 Sep 2023 09:42 PM
Hi, did you find a solution? I'm having the same issue this week. Also have LG tv
19 Sep 2023 10:07 PM
still no solution to this, driving me mad, I have checked software updates, reset the system, retuned the remote, still the same, surely everybody cant have a faulty lg tv
19 Sep 2023 10:20 PM
It's so annoying! It's just done it 3 times in the last hour.
