24
Discussion topic: TV loosing volume & switching off & on when fast forwarding sky q
This message was authored by aarondowds This message was authored by: aarondowds
Looking for help. My TV keeps loosing volume & switching off when fast forwarding sky q
This message was authored by Chodley This message was authored by: Chodley Answer
Re: TV loosing volume & switching off & on when fast forwarding sky q
I would still try resetting it and picking the model again Random stuff happens. Neutrino from space hits a transistor etc 😉
Sounds like the remote is set up for the wrong TV model
aarondowds
thanks for the reply, I have been using the same remote since the start but its only just started doing it recently
I wouldn't expect it to change its coding but
Might be worth re-doing it anyway.
or a button is stuck down?
aarondowds
Thank you, I have reset it, fingers crossed.
This message was authored by RayH73 This message was authored by: RayH73
Did that work? We have same problem
aarondowds
No it didnt work,still having the same issue, it is driving me nuts, too many people complained for it to be my TV , Im starting to think its sky now
What TV is it? Do you both have the same ?
Good question. LG TV model
43NANO756PR
aarondowds
Mines is also an LG but a different model. Im wondering if there is a setting needing adjusted
I think it's possible to use various LG IR codes on the Sky remote. Maybe some work better than others.
aarondowds
I know nothing about IR codes, maybe time to call sky , this is driving me crazy
This message was authored by kanny This message was authored by: kanny
Hi, did you find a solution? I'm having the same issue this week. Also have LG tv
aarondowds
still no solution to this, driving me mad, I have checked software updates, reset the system, retuned the remote, still the same, surely everybody cant have a faulty lg tv
It's so annoying! It's just done it 3 times in the last hour.
