Discussion topic: TV keeps showing no internet connection yet other devices are connect. Sky Q box have to reset
This message was authored by: Robbo4321
Main sky box keeps saying no internet connection yet other devices are connected to it. Upstairs Sky Q box has to be reset every morning.
Re: TV keeps showing no internet connection yet other devices are connect. Sky Q box have to reset
Hi @Robbo4321
First check that you are not trying to use the Mini in the early morning if your Main Q box is in Eco standby.
https://www.sky.com/help/articles/using-the-standby-settings
If this is not the issue
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
