Discussion topic: TV keeps flicking to black screen every few seconds
Message posted on 25 Jan 2025 08:38 PM
When watching TV the signal seems to get interrupted and the screen flashes black and sound stops. I have changed hdmi cable. Rebooted sky box. Changed hdmi cables. Changed picture resolution. Reset internet. changed input ports and nothing fixes it.
Message posted on 25 Jan 2025 08:42 PM
Re: TV keeps flicking to black screen every few seconds
Message posted on 25 Jan 2025 08:54 PM
Hi @oldfella, thanks for your speedy response. Have done the above but unfortunately still having the same problem 😞
