Discussion topic: TNT sports channels 1-4 ‘no satellite signal”
Message posted on 14 Aug 2025 11:00 AM
I can get all the channels on my Sky Q no problem with the exception of the 4 TNT sports channels. Just says 'no satellite signal' on each one. Strangely I can get the TNT UHD channel enabling me to watch the Spurs game last night.
anyone else have this issue ?
I've gone through all the usual steps that Sky recommend to retune but it surely can't be a satellite signal issue as I have no problems for watching any other channel.
Message posted on 14 Aug 2025 11:02 AM
Re: TNT sports channels 1-4 ‘no satellite signal”
It can be. If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
Message posted on 14 Aug 2025 11:07 AM
Thanks, appreciate your suggestion. I'll check this but surely a faulty connection would affect all channels and not just the 4 from one 'supplier' ie TNT ?
Message posted on 14 Aug 2025 11:08 AM
Not on a shared dish by the way
Message posted on 14 Aug 2025 11:10 AM
And why can I still get the TNT uhd channel ?
sorry, realise you don't have all the answers Just thinking out loud here !
Message posted on 14 Aug 2025 11:20 AM
@PRM7859 wrote:............And why can I still get the TNT uhd channel ?
TNT Sports Ultimate is broadcast from a different satellite transponder from the other TNT HD channels.
( 12.207 GHz V Tp26)
Which suggests to me that you need to have the aim of your satellite dish re-optimised.
Godfrey.
Message posted on 14 Aug 2025 11:25 AM
Ah, I see. Thanks for that., very helpful. 👍
Message posted on 14 Aug 2025 11:26 AM
It's very possible for only one frequency carrying a certain group of channels to be affected. In this case TNT 1-4 are all broadcast on the same frequency but TNT UHD is seperate which is why that is still working.
Quite often on here people are reluctant to believe it's a dish alignment fault when only one group of channels is affected. but that's how most dish alignment problems start.
Message posted on 14 Aug 2025 11:31 AM
@PRM7859 TNT also choose to use the Europe satellite beam and not the UK satellite beam, so their satellite signals will always be around 3 dB weaker than any UK beam channels.
Thus, satellite signals broadcast from the Europe beam will normally be the first to show signs of degradation as a satellite dish moves from its optimal reception position.
Godfrey.
Message posted on 14 Aug 2025 11:42 AM
Thanks Godfrey, that does all make sense. I've not been watching any of the channels much lately, but come to think of it, the last time I did the picture did keep breaking up..pixellating...so I guess the alignment was changing. Does this mean I need a visit from sky to fix ? 😩
Message posted on 14 Aug 2025 11:45 AM
@PRM7859 wrote:..........I've not been watching any of the channels much lately, but come to think of it, the last time I did the picture did keep breaking up..pixellating...Does this mean I need a visit from sky to fix ? 😩
Yes.
Godfrey.
Message posted on 13 Sep 2025 08:49 AM
I have exactly the same problem and have tried everything incl calling out an Engineer.
Still no change.
Did you manage to sort out your problem as I am running out of ideas ??
Many thanks
Message posted on 13 Sep 2025 10:22 AM
Still no change.
And what did the engineer do / say? Did he not try a TNT channel before leaving?
Message posted on 13 Sep 2025 11:17 AM
Usual reminder that you can watch all of the TNT Sports channels live via the discovery+ app on your Sky Q box if needed, just make sure it is activated in time.
No you can't record and yes I know it doesn't fix the satellite issue, but it does let you watch what you are paying for while you are getting a fix in place.
LG B6 OLED 55” | LG UP75 LCD 43” | sky Q | sky Q Mini | SONOS Beam 2 | Apple TV 4K | EE Full Works FTTC
Message posted on 13 Sep 2025 06:32 PM
I renewed my contract with sky yesterday and was advised that I had to watch the 4 TNT channels through the Discovery Plus app. this worked.
I only ever watch the football on TNT, not bothered about anything else's and the premier league or champions league games are on the UHD channel which I can still get without any problems so overall I'm not too bothered.
As I sit and write this, I've just tried the 4 channels again and to my surprise they're all there and I didn't go through Discovery plus !
Before you ask...I've no idea !
