Discussion topic: TNT Sports picture pixelated or no signal
This message was authored by: RossDuncan
For the last month my TNT sports picture keeps breaking up or losing signal every time I watch live sport, even though other channels are fine. Can someone from Sky help me with this?
Re: TNT Sports picture pixelated or no signal
I'm sure they can if you contact them.
@RossDuncan
You mention no signal in your thread title. If you are seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It may then give you the opportunity to arrange an engineer. If it doesn’t you’ll need to contact Sky to book an engineer appointment.
It’s worth mentioning that:
🔹 a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels (amongst the first to be affected may be TNT or GB News),
🔹 wind and rain can affect the satellite signal and following adverse weather wait times for an engineer will probably be significantly longer.
🔹a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
