Discussion topic: TNT Sports channels in the wrong place
Message posted on 27 Jun 2024 10:09 AM
Hey All,
Can I check if your HD channels for TNT Sports are 410 etc? Mine is showing SD at the moment.
Message posted on 27 Jun 2024 10:16 AM
Re: TNT Sports channels in the wrong place
What sky are you on? Sky q, sky+HD?
What about the stations in the later section? Maybe 868, 869, does an issue show for those?
ROI sky Q Customer.
Message posted on 27 Jun 2024 10:19 AM
I'm on Sky Q sorry
Message posted on 27 Jun 2024 10:43 AM
868 etc show them in HD, but the other channels are in SD. It should be the other way around.
Message posted on 27 Jun 2024 02:14 PM
@Austinored Have you tried rebooting your main Q box ie
Message posted on 27 Jun 2024 02:17 PM
Yes I have. Still the same, so I have scheduled a call with Sky. I'll update you soon.
Message posted on 27 Jun 2024 02:49 PM
@Austinored Are you paying sky directly for tnt access or bt/tnt direct
Message posted on 27 Jun 2024 03:30 PM
I'm paying via BT, but it's clearly for HD for Sky
Message posted on 27 Jun 2024 05:18 PM - last edited: 27 Jun 2024 05:20 PM
@Austinored if you are paying bt there is an additional charge of about £7pm for the hd variant so do you have this on your bt account
are you able to watch the hd version even though they are in the wrong position on the epg
Message posted on 27 Jun 2024 05:33 PM
Yes I can see both versions, it's annoying that for some reason my guide has changed. I've called BT and checked I'm paying for it properly. Sky said they can't do anything... which is weird as they are the only ones who can change the guide. I've never had this issue before mind. I've emailed them again, let's see what they say
Message posted on 27 Jun 2024 07:30 PM
BT can barely manage the channels on their own so called "TV service", they certainly will not be able to influence the order of channels on the Sky Q TV Guide.
Sky will need to help you resolve this, it seems the normal 'SD > HD' swap has gone a bit wonky.
LG B6 OLED 55” | LG UP75 LCD 43” | Sky Q | Sky Q Mini | Sky Soundbox | EE Apple TV 4K | EE Full Works FTTC
