Discussion topic: TNT Sports channels breaking up/pixellating
This message was authored by: MWy
Hi all
Just renewed contract with Sky (like for like) and now I cannot get solid picture on any TNT Sport channels, particulalry in evening.  Picture on all Sky Channels is perfect at all times.
Pixelated picture comes and goes with blue screen which has message "This channel is currently affected by a problem with your satellite signal."  No idea what it means (!) but I read a bit and changed the LNB setting to SCR (from Wideband) but then got no services at all.  Swapped back to Wideband and all back (except the TNT Sports channels).  Also done a reset through 001 Settings.
Any other suggestions so can watch the fotball tomorrow PLEASE!
mvw
Re: TNT Sports channels breaking up/pixellating
@MWy
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
This message was authored by: KayleighT
Hi did you get a fix for this ours does the same all the time.
