2
This discussion topic has been answered Discussion topic: Synching sound to sound bar with a new remote
This message was authored by: Gwen+Farclas
My Sky Mini-box remote developed a fault.  So, Sky sent me a new remote.  While the remote works OK, the old remote was synched for sound control with the Sony soundbar I use with my TV.  When I switched to the new remote, it does not have control of the sound from the sound bar.  I need to switch remotes to the Sony one to change the sound level.
Does anyone know a way to synch the Sky remote to the Sony sound bar?
C.
This message was authored by: nigea99 Answer
Re: Synching sound to sound bar with a new remote
hi @Gwen+Farclas
You need to pair the remote :
May I suggest you try a reset of your remote first :
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV  & Soundbar - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
hi @Gwen+Farclas
Avatar for Gwen+Farclas
Great - that has fixed it.  Many thanks for your speedy reply. 👍
C.
