This discussion topic has been answered Discussion topic: Synching sound to sound bar with a new remote
Message posted on 20 Jul 2025 08:00 PM
My Sky Mini-box remote developed a fault. So, Sky sent me a new remote. While the remote works OK, the old remote was synched for sound control with the Sony soundbar I use with my TV. When I switched to the new remote, it does not have control of the sound from the sound bar. I need to switch remotes to the Sony one to change the sound level.
Does anyone know a way to synch the Sky remote to the Sony sound bar?
Message posted on 20 Jul 2025 08:03 PM
You need to pair the remote :
May I suggest you try a reset of your remote first :
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV & Soundbar - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
Message posted on 20 Jul 2025 08:14 PM
Re: Synching sound to sound bar with a new remote
Great - that has fixed it. Many thanks for your speedy reply. 👍
