Discussion topic: Sy Q settings say you have no internet connection but tests ok and all lights green on router
This message was authored by: HTimpe
Cannot access any of the features such as Catch Up, On Demand, Apps.  Ready to return SkyQ as useless
Re: Sy Q settings say you have no internet connection but tests ok and all lights green on router
Hi @HTimpe
if you are on 3rd party (non Sky ) broadband or have the new Sky Max router then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Avatar for HTimpe
Thank you.  Connected for now!!
