3
Discussion topic: Switching from Sky Q to LG OLED 55 C24
This message was authored by mirdragon This message was authored by: mirdragon
When my contract runs out, I'm looking at ditching Sky Q. My TV supports Freesat but will I need to change my Sky Q LNB for a different model.
I've plugged one of the cables in and it's done a scan, it lists over 130 TV channels and can get the egp, but every channel reports 'invalid signal' which makes me think I would need a different LNB. The TV only accepts one cable.
I can't find anything within LG documents and their phone support wasn't that good.
If I need a separate LNB do I need a specific one? Could I move cable and wire into my old LNB on my other dish (Sky never seem to take older dishes down and just put up new dishes.)
Zen Internet: G.Fast (330/50)|OpnSense + UniFi Cloud Gateway Ultra
Mobile: Apple 16 Pro Max 512GB|Samsung Tab S6
TV: LG OLED55C24LA|Freesat 4K|2xHDHR Quatro
AVR: Marantz NR1711
Streaming Devices: Xbox Series X|Apple 4K TV|Fire TV Cube|Shield TV Pro|Roku 3
This message was authored by Godfrey This message was authored by: Godfrey Answer
Re: Switching from Sky Q to LG OLED 55 C24
@mirdragon wrote:
When my contract runs out, I'm looking at ditching Sky Q. My TV supports Freesat but will I need to change my Sky Q LNB for a different model.  YES
I've plugged one of the cables in and it's done a scan, it lists over 130 TV channels and can get the egp, but every channel reports 'invalid signal' which makes me think I would need a different LNB. The TV only accepts one cable. You would need to change the Sky Q WIDEBAND LNB for a Legacy UNIVERSAL LNB
If I need a separate LNB do I need a specific one? Could I move cable and wire into my old LNB on my other dish. YES
You will need to feed your Freesat TV from a Legacy UNIVERSAL LNB, and there is a strong possibility that this is the type of LNB was fitted to your old satellite dish.
mirdragon
Thanks for that, I had a feeling that would be the case, but would it be same if I decided to get a Freesat box instead? Don't the newer ones works with Sky Q LNB?
AVR: Marantz NR1711
The 'Freesat 4K' branded boxes do.
Unfortunately manufacturers are still fitting older (and presumably cheaper) satellite tuner components even into 'premium' range television sets and so these can't get a Freesat signal through a Q LNB.
