2
This discussion topic has been answered Discussion topic: Switched to full fibre, what do I do with old broadband router ?
This message was authored by: Monkeyboy7
Recently moved from broadband to full fibre and have old router , do I throw away or do Sky want it back , if so how does this work
This message was authored by: hrai Answer
Re: Switched to full fibre, what do I do with old broadband router ?
Contact Sky and ask them. They will either send you a prepaid envelope to return it or say it's yours do as you see fit. Keep it until you hear back from them.
Even if they then say you can chuck it etc. make sure you keep a copy of the reply just in case that in a years time their IT system decides that you now need to return it or pay a £60 penalty!
@Monkeyboy7
It depends which hub it is. Sky may not request the Sky Q router and other now obsolete ones back.
