Discussion topic: Swift fibre drops out when connecting sky q
This message was authored by: CFev
My sky q drops out all the time 1 boxes upstairs are useless as always no connection I watch the WiFi tick it keeps coming in and off on main box please help
Re: Swift fibre drops out when connecting sky q
@CFev
Most people don't realise but, unless you have Sky Broadband, the Q mini boxes only ever connect to the main Q box via there own 5ghz mesh, they do not connect to your router.
If you are having issues it usually means the mini is too far away from the main Q box or trying to connect to the wrong thing or there is interference to the Q mesh from your Swift router set up.
I am with BT, to prevent my Smart Hub 2 from interfering with the Sky Q mesh I had to change the 5ghz frequency in the hub away from MHz channel 36, which Sky Q uses.
LG B6 OLED 55” | LG UP75 LCD 43” | sky Q | sky Q Mini | SONOS Beam 2 | Apple TV 4K | EE Full Works FTTC
Avatar for CFev
I understand that but why would the main box keep loosing internet it has a node  next to it and the router is around 4m from it ?
i have had issues with my q mini boxes for years with BT so nothing new but never the main box
I can sit and watch the main box go on and off over and over again ?
Usually because the main Q box only connects to the 2.4ghz band of a non Sky router and there is then a problem which forces the connection to drop, like band steering or similar on the router (no seperate bands).
I can't diagnose that issue on an anonymous forum, but if it has been happening on your previous ISP and now Swift, have you had a Sky engineer out?
Is it possible to connect the main Q box to the router via ethernet if it is only 4M away?
Avatar for CFev
Potentially yes but it does say that wiring to router cuts out the Wi-Fi to the a boxes is this correct as when you go through the set up you turn off the Wi-Fi to get the wired option ?
Here is how I have mine:
  • Main Q box hard wired
  • 2.4ghz WiFi  turned off
And that's it. The main Q box will create a 5ghz mesh for the mini boxes to connect to.
Avatar for CFev
Brilliant great advice gunna give it a try many thanks for your help
Let us know how you get on.
