4
This discussion topic has been answered Discussion topic: Subscriber with a box and want a new one for another room.
This message was authored by: Mitzi999
I have a Sky Box subscription. I would like to have Sky in another room. What do I do?
Thanks x
Re: Subscriber with a box and want a new one for another room.
@Mitzi999
Give Sky a call and order a mini box (or boxes - see below) and a multiscreen subscription.
You can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a 3rd mini box at the same time if you’re using it for one of the apps such as Netflix.
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
@Mitzi999
Avatar for Mitzi999
Aww thank you so much 🙂
This message was authored by: Dazzer_pvfc
My hardware version is 32B*** does this mean I can get 4 boxes
@Dazzer_pvfc
Yes, you can have a maximum of 4 mini boxes loaned to you by Sky. You can only watch Sky content on two minis and the main box at the same time. You may be able to use a 3rd mini box at the same time if you’re using it for one of the apps such as Netflix.
Answered - Go to Answer
