Discussion topic: Step 1 of 4. Remote won’t do anything. Changed batteries
Message posted on 26 Oct 2023 05:54 PM
Message posted on 26 Oct 2023 05:56 PM
Re: Step 1 of 4. Remote won’t do anything. Changed batteries
Still waiting
Message posted on 26 Oct 2023 05:58 PM
Remote
need help. Remote won't work
Message posted on 26 Oct 2023 06:07 PM
Hi @Jay691
First press 7 & 9 together on the remote until it's led flashes 4 times.
then the remote will control the Q box in infrared.
You must point the remote at the Q box.
Once you get back up and running you will need to completly resetting your Bluetooth remote again.
Message posted on 26 Oct 2023 06:20 PM
@Jay691 just so you are aware you are not contacting Sky's customer services on here, this is a customer to customer forum where customers help each other.
