Discussion topic: Sqy q no signal won’t come on
Message posted on 23 Aug 2025 03:38 PM
My squ q won't come on the telly it's says no signal on the screen
Message posted on 23 Aug 2025 04:24 PM
Re: Sqy q no signal won’t come on
@Kareema1
No signal and no satellite signal issues are different .
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
