Discussion topic: Speech on some channels is distorted
Message posted on 12 Apr 2026 12:06 AM
Message posted on 12 Apr 2026 08:03 AM
Re: Speech on some channels is distorted
@George792228 wrote:
On some channels the sound is distorted
Which Sky system do you use George and which channels are affected?
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
2 Windows desktop PC's hardwired to each Deco, everything else using the Deco WiFi
Message posted on 12 Apr 2026 08:21 AM
What do you use to listen to SKy - TV, Soundbar or Av system ?
Which ever may I suggest you check & possibly change the setting in
Home - Settings - Setup - Audio Visual
Digital audio output HDMI
to Normal
Distorted speech often comes from channels using 5.1 sound and the Sound system used being unable to handle the centre channel (deffective speaker or similar) - setting the above to Normal means you only get 2.0 sound
