Soundbar
Runner
Post 1 of 10
Soundbar
Just bought polariod soundbar from asda and tried to connect remote, but it sky q box says not supported.. is there any way of connecting my sky q remote?
Managing Editor
Post 2 of 10
Re: Soundbar
Try searching at https://sky.uebv.com. If it’s not listed there it probably not supported. Most of Polaroid’s hardware is rebranded from small 3rd party factories in countries such as a Turkey . Unless Polaroid can give you an alternative brand name to search you are probably going to be out of luck.
Runner
Post 3 of 10
Re: Soundbar
Cheers I'll try that
Runner
Post 4 of 10
Re: Soundbar
Same here. Did you get it connected?
Runner
Post 5 of 10
Re: Soundbar
Hi,
No didn't get it done.
Don't know what to do now 🤔
Runner
Post 6 of 10
Re: Soundbar
I've had a play and can't get it to change volume with either my tv or sky remote. If I find something I'll let you know though.
Runner
Post 7 of 10
Re: Soundbar
Cheers, that would be much appreciated
Sound Supervisor
Post 8 of 10
Re: Soundbar
Have you tried one of the Polaroid TV codes perhaps?
  • 1673
  • 2704
  • 1304
Runner
Post 9 of 10
Re: Soundbar
How do you put in the 4 digit codes on Sky Q?
Runner
Post 10 of 10
Re: Soundbar
Just tried it myself and you can't on sky Q.
Well can't see where you can anyway.🤔
Recommended Threads
