Discussion topic: Soundbar connect to sky q remote
Message posted on 01 Dec 2025 07:44 PM
Looking to connect my garagerock soundbar to sky q remote but not on list of soundbars is there a default pin i can use
Message posted on 01 Dec 2025 07:52 PM
Re: Soundbar connect to sky q remote
Message posted on 01 Dec 2025 07:54 PM
It does but when i click just says my soundbar is not compatable but would be good if you could manualy input the brand ?
Message posted on 01 Dec 2025 08:12 PM
Hi @Rico4
If the Soundbar has HDMI control (CEC) settings and this is turned on in your Television and Soundbar, then the volume should change with Television volume.
Message posted on 01 Dec 2025 09:38 PM - last edited: 01 Dec 2025 09:47 PM
That wouldn't achieve anything if Q doesn't have the appropriate instruction set, which has to be provided by the manufacturer to Sky.
Given the price-point which that brand is apparently targeting, it's quite possible they haven't done so.
