Discussion topic: Sound keeps going off where i have to switch sky off and then back on again. Also today has starte
Message posted on 04 Sep 2024 09:45 AM
At first the sound would keep going off and have to press power off button on remote then turn back on again and today it has started freezing and won't do anything so have to turn off at power and reboot.
Message posted on 04 Sep 2024 10:37 AM
Re: Sound keeps going off where i have to switch sky off and then back on again. Also today has st
Hi @Tracey06 .
