Discussion topic: Sound keeps cutting out and have to switch sky off and back on to get to work
This message was authored by: Richard+Freshwate
Sound cuts out and have to switch sky off and back  on to make work
Re: Sound keeps cutting out and have to switch sky off and back on to get to work
Hi @Richard+Freshwate
