Discussion topic: Sound cuts out and stops sometimes. Picture has interruptions also.
Message posted on 03 May 2024 10:15 AM
While watching Sky channels the sound will just stop. Also the TV picture can fli k on and off. I have unplugged, reset, and checked all the cables and connections and they are fine.
Message posted on 03 May 2024 10:18 AM
Re: Sound cuts out and stops sometimes. Picture has interruptions also.
Hi @Neil2563
When you say reset have you reset the Settings in the hidden menu?
Message posted on 03 May 2024 10:36 AM
Yea just tried this so hopefully okay now
