Discussion topic: Sound but no picture from sky q box. Rebooted twice. Pixelated writing on screen.
This message was authored by: bouldner
Sky q box not working. Can get sound but no picture Rebooted twice. Writing on screen after rebooting pixelated. Checked all connections and broadband all working normally.
Re: Sound but no picture from sky q box. Rebooted twice. Pixelated writing on screen.
Hi @bouldner
