Discussion topic: Sorry because of a technical issue you’re experiencing a limited service. Please be assured that we’
This message was authored by: fzPhil10
Getting this message - Sorry because of a technical issue you’re experiencing a limited service. Please be assured that we’re working hard to fix the problem.
it ages to bring up menu, can't get to apps. Half the icons are missing when the menu does come up. Just blank blue squares in places. Menu randomly tells me there's no internet yet when I go to setting it fine. Frankly the box is currently next to useless . . ?
Re: Sorry because of a technical issue you’re experiencing a limited service. Please be assured that
Hi @fzPhil10
Avatar for fzPhil10
Sky Q box registers I'm on line so it's not the router. If it was the router it would surly say not connected to the internet?
Hi @fzPhil10
My post is just intended for you to reconnect the WiFi to the Q box.
Assume you have tried rebooting your Q box?
Have you tried rebooting your Q box?
Avatar for fzPhil10
Tried that's ago and my router works fine. The Sky Q box even says it connect to the router.
This message was authored by: JonD1492
Have you tried rebooting the Sky Q box itself?
Power it down, then remove the power cable from the back of the box, and unplug it. (You WON'T loose any of your recordings or timers!)
Wait for 2 minutes, then reconnect the power.  Let the box reboot, and once it has, see if that fixes things.  Sometimes the box can get a bit "bunged-up" and needs to cleanse itself of the bug that's causing the problem.  Rebooting it should fix it.
Hope it works for you!
This message was authored by: catbear
I have had the same thing for three days now. Waiting for recordings to play. Some recordings on planner invisible blue squares, Blank blue screen when I try to watch anything I have recoorded. Message sometimes says 'Please Wait' which I do and sometimes I am lucky sometimes not. Sky search does not recognise anything I search for despite it being listed on my planner. and on programme guide. Voice recognition is OK but I get notice informing me that it does not recognise my request. This is so very very very frustrating especially as my bill has just been 'upped'.
Internet is connected I have good signal strength
Hi Catbear,
Two things to check are:
1 - Have you emptied your "Deleted Recordings" folder?  If it's full to bursting with weeks/months of old recordings you don't need anymore, permanently delete them.  If the folder is full of stuff, it can interfere with the box working optimally.  You should empty it fully, regularly.
2 - Is your box running at almost-full-capacity, e.g. it's 90% (or more) full?  If it is, then that can also cause problems, and you may have to make some tough choices to delete stuff that you no longer need, or can perhaps be bought on physical media instead if you really want to keep it.  Again, Sky boxes need to have 15%-20% leeway of free space to allow for other stuff to be done, and a box that's too full of stuff, will start to fail if it's running at capacity or near-capacity.
Try doing these two things, and seeing if that helps.
