43
Discussion topic: Sony TV freezing and rebooting with SKY Q
This message was authored by Stevan This message was authored by: Stevan
Hi - I have recently (October) purchased a Sony Bravia 8 tv and installed it with sky q box . I have the same issues as others mention with Tv freezing and randomly shutting down and rebooting. This only seems to happen on sky q both on live tv and playback ( not Apple TV ) . I have updated firmware on both and reset , turned off hdmi control , checked all energy settings and power off settings , all to no avail . I have also replaced sky q box and no joy. Issue occurred three times yesterday. Can anybody offer an update or solution on what appears to be an ongoing software issue ? Thanks in advance for any help.
Stevan
This message was authored by Stevan This message was authored by: Stevan Answer
Re: Sony TV freezing and rebooting with SKY Q
Hi .... so after many long days of research I found an article about samba interfering with sky q on Sony tv's and causing issues in other arenas. I have disabled samba on Sony Bravia 8 and turned hdmi off on sky q - The Tv has not frozen or rebooted for 8 days - (it was doing it daily) - I have now enabled hdmi control on sky q but kept samba off and so far so good.  It appears at face value that samba causes a software glitch in sky q .
hope this helps
This message was authored by TanerC This message was authored by: TanerC
Man finally I found someone with the same issue it's been driving me crazy.  Have no idea what it is. Sky are saying it's the tv and Sony don't know why it's happening either. I thought the tv was faulty so had it exchanged and it still happens I also have Sony Bravia 8 and this only happens with sky q.  I'm going to have to cancel sky cos this ain't acceptable.
Also this didn't happen with my old Samsung tv so it's something to do with the Bravia 8 and ska q connection but definitely a sky issue otherwise the tv would be restarting while watching on other devices and ps5 too but it's not.
This message was authored by Chodley This message was authored by: Chodley
I'm sure other Sonys have had a similar issue. I think turning hdmi-cec off might help but is less convenient.
thanks I already did that and still have the issue so not sure what else
On both the TV and Sky box?
Stevan
hope this helps
Stevan
hope this helps
Out of interest - what is samba? Is that the file network protocol or something "Sony"?
Stevan
Samba is an "app" in Sony settings that you can disable in the menu settings of the TV. As I understand (I am not an expert) it tracks viewing and activity to enable recommendations etc.
Turn this off on the Tv and no more freezing and rebooting with sky q .
Hi just checking if you had any rebooting since turning off samba ? And how many days has it been ?
Stevan
I have had no rebooting or freezing over two weeks since turning off samba and operating tv with Sky q - previously it was happening daily - all the best and hope it works for you !
This message was authored by Jerve This message was authored by: Jerve
Hi I've had he same problem have now turned Samba TV off. Have you had any reoccurrence of the problem?
Stevan
Now almost three weeks with no issues since turning samba off in settings on Sony tv .... fingers crossed ... all good !
This message was authored by Tej+Saran This message was authored by: Tej+Saran
Hi. I also have the same issue with a new Series 8 Sony OLED TV. could you please clarify if I need to do anything with the 'HDMI Control' as well as turning Samba off?
Also, is Sky Q now working issue free for you?
Many thanks.
