4
Discussion topic: Sony Bravia KD-85X85J HDR Error - UH021
This message was authored by Clobberhand This message was authored by: Clobberhand
Can anyone help with a HDR 10 bit problem?
I have 8 bit enabled, but whenever I try and change to 10 bit, I get Error: UH021. It is saying my TV is incompatible, however I have the HLG and HDR10 options on the TV settings (have tried changing to HLG to no avail - still only allows 8-bit).
I have swapped the HDMI and have the pink tipped Sky lead installed. Have also tried a couple of different HDMI ports to rule that out too.
Q Box is HW ver - 32B107
TV - Bravia KD-85X85J
So I believe I tick all the boxes required, could I have a fault or I am I just being a derp?
Cheers.
This message was authored by MightyQuinn This message was authored by: MightyQuinn Answer
Re: Sony Bravia KD-85X85J HDR Error - UH021
Hi @Clobberhand   On your TV, Settings-> Channels & Inputs -> External inputs -> HDMI signal format-> HDMI x -> Enhanced format.
@Clobberhand Is there an option within your TV settings for Deep Colour, Enhanced Colour are any variation of this?  If so it would need to be enabled, check the user manual as this should have a refeyto external devices using HDR.
Samsung 75" 4K TV, Sky Glass Gen 2 55", Sky Stream, VM 1 Gig Broadband, Sony 7.1 AV Receiver, Technisat MultiSat receiver.
@Clobberhand  As @GD1 mentions  I think that on Sony the setting needed on the HDMI is 'Enhanced'
Clobberhand
Worked a treat @MightyQuinn my Eskimo friend! Thank you kindly.
Cheers also to @nigea99 and @GD1  for the steers in the right direction 🙂
