4
This discussion topic has been answered Discussion topic: Sony 48" OLED HDR 4K UHD Smart TV MINIBOXES AND UPGRADING TO SKY SIGNATURE
This message was authored by: angelwings123
WILL MINIBOXES STILL WORK THE SAME? AND IS IT WORTH ME UPGRADING TO UHD  FOR PICTURE QUALITY,ALSO I HAVE BRIGTHNESS SETTING ON THE TV A LITTLE LOWER DUE TO MY VISION BUT THE PICTURE IS JUST OUTSTANDING,ALL ADVICE AND HELP WOULD BE VERY HELPFUL PLEASE .THANK YOU ALL SO MUCH (CAPS DUE TO VISION)
This message was authored by: Laing1 Answer
Re: Sony 48" OLED HDR 4K UHD Smart TV MINIBOXES AND UPGRADING TO SKY SIGNATURE
@angelwings123 wrote:
BUT THEY WILL STAY AND WORK THE SAME I WONT NEED TO DO ANYTHING>THANK YOU SO MUCH .
@angelwings123 if you upgrade to Sky Signature your mini boxes will work as they do at the moment
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Hi @angelwings123   Sky Q Mini boxes do not support UHD (4K) pictures. Their maximum resolution is HD.
Avatar for angelwings123
Level 3 icon
Level 3 icon
THANK YOU SO VERY MUCH  SILLY QUEATION I KNOW BUT I JUST WANTED TO CHECK,NOW UPGRADED THANK YOU SO MUCH FOR YOUR TIME AND HELP.
Answered - Go to Answer
