Discussion topic: Some channels showing error-no satellite signal
This message was authored by: kuli
I cannot view some channels. Error message states no satellite signal
Re: Some channels showing error-no satellite signal
@kuli Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
@kuli
If it continues to show no satellite signal take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. If you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
