Discussion topic: Some channels affected by satellite sognal
This message was authored by: J9clements
Certain channels such as itv 103 and Sky sports 402 saying we have no satellite signal. We pay for Sky sports too. Also itv 103 is a free channel. All other channels work fine
Re: Some channels affected by satellite sognal
@J9clements
I take it you have a Sky Q box as you had posted this in the Sky Go forum so I have moved this to the Sky Q forum for you.
@J9clements
If you do have Sky Q…
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
