2
This discussion topic has been answered Discussion topic: Smart to suddenly not seeing sky q box
This message was authored by: Tina917
I have a smart tv. Last night the to suddenly didn't recognise the hdmi link. Nothing on screen. Changed cable twice. Switched ports still just says SkyQ  no signal
This message was authored by: GD1 Answer
Re: Smart to suddenly not seeing sky q box
@Tina917  can you try the following:
Turn on your Q box using the remote, allow a minute or 2, then on your remote press the following buttons in this order Home1080Home.
This should default the box to 1080 allowing the TV to pick it up again.
Avatar for Tina917
Thank you @GD1  that has worked.
