Discussion topic: Skytv not connecting to Internet
This message was authored by: Lewis891
My sky box will not connect to my WiFi have reset the WiFi router and reset the sky box have also tried to reconnect WiFi manually nothing is working!!
Re: Skytv not connecting to Internet
Which Sky System do you have?
1. Sky Plus (Sky Plus Forum)
2. Sky Q (Sky Q Forum)
3. Sky Stream (Sky Stream)
I am NeurodivergentMy Sky FAQs: Glass Stream Go Plus
Avatar for Lewis891
I have sky Q with the superfast Internet
I have moved your thread to a more appropriate forum
Is this Sky Broadband you have @Lewis891 ?
Avatar for Lewis891
Yes I actually have the sky gigafast broadband it is working on everything else no problem
Hi @Lewis891
.Have you carried out a Network reset as follows:-
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button. You must do this within 2 minutes after carrying out the Network reset.
You have to hold the WPS button on the router until it's WPS light flashes Amber.
Avatar for Lewis891
Yes I had tried this multiple times and it didn't work but has worked this time thank you
