Discussion topic: Skyq boxes keep crashing and are slow. We have had them a long time.
This message was authored by: Joanna17
Skyq boxes keep crashing, disconnecting and are slow. We have had them serval years.
Re: Skyq boxes keep crashing and are slow. We have had them a long time.
Hi @Joanna17
Millions of Sky boxes are 6 or 7 years old.    Age is not an issue.
Try a Reset Settings in the main Q box hidden menu.
