Discussion topic: SkyQ mini box failing
Message posted on 08 Aug 2023 04:40 PM
For several months I have struggled with Sky Q mini box problems. It freezes in both live and recorded programmes. Sometimes won't connect to WiFi. Sometimes doesn't work at all. Keep rebooting and works OK for a while but problems keep repeating. It is under a year old so can I get a new mini box from Sky?
Message posted on 08 Aug 2023 05:09 PM
Re: SkyQ mini box failing
Hi @Dicoz
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
