8
This discussion topic has been answered Discussion topic: SkyQ mini box and BT disc
This message was authored by: Squareial
Is it possible to connect a mini box via a BT disc using the Ethernet ports.
I have the main SkyQ box working this way. It's just that the mini box in bedroom is unreliable.
This message was authored by: Chodley Answer
Re: SkyQ mini box and BT disc
Should do
I have my Q connected the same way but went with powerlines for the minis because discs were not in convenient locations for the minis. Wifi disabled on all of them.
Have you disabled WiFi on the Q boxes?
Avatar for Squareial
I have not disabled Wi-Fi as yet. Just considering the purchase of another BT Disc. Just asking will it work via the disc?
Should do
Yes, should work - it's how mine are configured.  (They don't like connecting via WiFi to a disc but fine via Ethernet but the back haul is WiFi)
Thanks to all.
I will go ahead and purchase my Disc and disable Wi-Fi on the mini. Hopefully a happy wife😂
This message was authored by: Des1867
How don't connect my sky Q box to a bt disc via the ethanet port?I can't seem to get them to connect ?
How is this acheived please ?
I have an Ethernet cable between my main sky q box & a bt disc but when trying to connect the sky box is showing no ip address obtained?
cheers
cheers
Turn off wifi and do a network reset on the Q
