19
This discussion topic has been answered Discussion topic: SkyQ how many mini boxes can I have
This message was authored by: 127Stuart
Hi all, I have a question for you; how many mini-boxes can I have IN ADDITION to my main box?
Re: SkyQ how many mini boxes can I have
@127Stuart
You can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a third mini box if the first one in use is being used for a streaming app ie: Netflix or DIsney+.
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
▪️I AM NOT A SKY EMPLOYEE ▪️
@127Stuart
Deleted  - as @Daniel0210  already answered (more fully)
Avatar for 127Stuart
Daniel0210,
Many thanks for your reply.
Stu
So, can I definitely have 4 mini boxes AND the main box loaned to me by Sky can I ?
hi @127Stuart
Yes you can have up to 4 minis on your account (each additional one is likely to incur an admin fee, even though they are loaned)
As @Daniel0210 's notes you can only use 2  minis at one time for SKY content (only 1 if you have the 1TB non UHD box)
No one who knows their stuff would include the main box when they use the term minis, so yes.
This message was authored by: Russell251
We currently have 2 HD+ boxes and about 10 tv screens using magic eye
If we upgrade to Q does that limit the number of TVs?
@Russell251
You may, also, wish to read some notes I have made for people considering switching from SKY +/HD to SKY Q
SKY +/HD to SKY Q
No current Sky product can provision that many screens.
Glass/Stream permits up to three Glass television sets and six Stream pucks (and would require 500Mbs or better FTTP). There's apparently a significant announcement regarding Glass due later this month (February 2025)
To get Sky Q to anything like that many points you'd need a fairly sophisticated HDBaseT setup.
We currently have 2 Sky HD+ boxes
is that possible with Q
@Russell251
You can only have one main Sky Q box and, as we've stated, a maximum of 4 mini boxes.
@Russell251
Sky Q has a fundamentally different topology to Sky+
The single main Q box contains satellite tuners and hard drive, and all associated Mini boxes access these (typically over WiFi generated by the main Q box itself)
As we are a multi generation house we could have 2 contracts
Answered - Go to Answer
