Discussion topic: SkyQ box won’t turn on
Message posted on 13 Aug 2023 09:56 AM
My sky Q box won't turn on
Message posted on 13 Aug 2023 10:09 AM
Re: SkyQ box won’t turn on
Hi @Ali8888
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 13 Aug 2023 10:10 AM
Won't turn on from what; standby or completely off at the plug? What colour light is on the front of the box? What have you tried?
