Discussion topic: SkyQ box saying no tv as connectivity issue. Nothing obstructing dish. Any help please
Message posted on 14 Jul 2023 07:33 PM
Suddenly my tv went off and SkyQ box froze. Now saying I can't watch tv at the moment due to connectivity problem. I have turned everything off, unplugged it and put back on. Still saying the same message. Checked sky dish and nothing is in the way. Can anyone suggest what I could try???
Message posted on 14 Jul 2023 07:36 PM
Re: SkyQ box saying no tv as connectivity issue. Nothing obstructing dish. Any help please
Hi @Nkjc
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
