Discussion topic: SkyQ box has no satellite signal (all channels) and loses connection to network (ethernet connectio)
Message posted on 09 Sep 2024 02:05 PM
SkyQ box working fine last night. Turned on this morning and 'no satellite signal' blue screen on all channels. Status shows no satellite signal and, a few seconds after rebooting drops the (wired) network connection. Sound like a new box required? Anything I can try before calling Sky?
Message posted on 09 Sep 2024 02:19 PM
Re: SkyQ box has no satellite signal (all channels) and loses connection to network (ethernet connec
If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Message posted on 09 Sep 2024 03:17 PM
Connections are fine. It is a communal dish, and the management company had an engineer in over a week ago who replaced some equipment(?). Everything working fine up until last night. There is 'No Satellite Signal' period, not just on a few stations and all of the main menu items, even Recordings say 'to use this service you need a satellite signal'
Message posted on 09 Sep 2024 03:19 PM
You need to get back on to your management company in that case.
Message posted on 09 Sep 2024 03:23 PM
I have, they said 'not our problem, call Sky'!
Message posted on 09 Sep 2024 03:27 PM
They are fobbing you off. It's their responsibility to contact their approved engineers not you.
Message posted on 09 Sep 2024 03:32 PM
Yes I know, but Sky have said they send an Engineer FOC so I'll just have to see what they say.
Message posted on 09 Sep 2024 03:35 PM
Hopefully the attending engineer will be appropriately trained to deal with communal set ups.
Message posted on 10 Jun 2025 09:52 AM
Perhaps he was but we had to get an independent installer to put things right!
Message posted on 10 Jun 2025 10:05 AM
Presumably not at your expense as that is something the landlord or Management Company should arrange as part of any service fees. You may have to check the T's and C's of your tenancy agreement on that.
Message posted on 10 Jun 2025 11:45 AM
Yes it was at no expense to us. The management company footed the bill.
