5
This discussion topic has been answered Discussion topic: SkyQ EM150 box and Panasonic TV incompatible?
This message was authored by: whigiaw
Hi, I have just connected a Panasonic TV to replace an ancient 2nd TV, a Samsung. Having connected the Panasonic TX-24MS480B model  to the SkyQ box, the box is  not accepted. Message on TV reads this screen does not support HDCP.  Try reconnecting your HDMI cable or use different screen.
Is this correctable or should I return the TV.
Help please.
Avatar for whigiaw
This message was authored by: whigiaw Answer
Re: SkyQ EM150 box and Panasonic TV incompatible?
@bemak187
@GD1
The fault is the TV does not connect properly to the Mini box.  The error message being “This screen does not support HDCP . Check cable etc etc”
Hi, Thank you for your suggestion sorry about the delay in replying;
I can confirm that the fault is not caused by the HDMI cable. It is the correct type and used up to the day the TV was changed. The mini box was also the one that worked immediately before the TV change.
The box was and modes HD 1080 I and 1080p
I was able to get a correct display by disconnecting mains power to the box and TV.
On reconnecting the box reset as usual and the display showed correctly.  Unfortunately the next time the box/TV was turned on the fault reappeared. Multiple resets were used, all cleared the fault but switching off either TV or Mini box resulted in the fault reappearing.
I did note that for a fraction pf a second before the Blue screen and error message, a picture could be seen. I think this probably a source generated.
Once again thanks for the help.
This message was authored by: bemak187
@whigiawAre you using the cable that came with the sky box?  That TV suupports HDCP 2.2 based on the specs of it.
@whigiaw  If the box was left in UHD (2160p) this may be causing an issue.  Try resetting the putput on the Q box, with the box switched on use the Sky remote and Press Home-1080-Home.
If you then see a picture you should be able to put the box back into 2160p
@whigiawIs this a mini or the main box as you mentioned an EM150 which is a mini.
Avatar for whigiaw
@bemak187
@GD1
This message was authored by: ThePope27
Hi @whigiaw
Put one of these between the sky q box and the tv, it will sort all your issues out
https://amzn.eu/d/7v8XaHV
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
